- Jul 18, 2011
- 18,168
Greetings,
A little venting session. . . .
I started my annual ritual of getting the boat ready for its seasonal launching.
Winter cover comes off
Batteries look OK
Initial starting of the engines.
VesselView says
Starboard is OK - Starts up, water flowing, oil & temperature are good.
Port engine - VesselView initially says OK- I start it up . . . water pressure is really low . . . barely any coming out of outdrive ports. Shut it down re-check everything.
Re-start port engine . . . now has an alarm (fuel system
). I get the engine running, water seems to be flowing better, but pressure is fairly low. Fuel usage per hour (at idle speeds in lower than starboard engine 1.1 vs. 1.4)
I run the descaler solution on both engines ( SeaCore - closed cooling ) and let it sit overnight, hoping that will help the water flow on the port engine.
I figure I will plug in my Diacom computer and in the AM and find out what is going on with the port engine. . . . and the hits just keep on coming . . . Diacom computer is dead, showing no signs of life
. Now I'll have to load up another laptop with the software. Oh joy . . .
Batteries look OK
VesselView says
