My boat run slowly. 120HP,2.5L,1989
liusigou
My engine can run with maximum speed of 33 miles a week ago. But it run rough with maxinum speed of less than 10 miles yesterday. What happened my engine?
alldodge
We don't know, your going to need to do some testing
Suggest
Do a compression test
How long have you owned the boat?
liusigou
Today I did a cylinders pressure testing. They are 130, 130,100, 130. Last year the third was 120. Can it be fixed?
alldodge
Not bothered by the one at 100, could be anything and not really be a factor when running
That said, if your gauge is accurate then the motor may just be getting tired
Is the timing set correctly, is timing advancing and if so how much?
How do the plugs look, all the same or different?
liusigou
They are nearly the same. I only took pics of three.
liusigou
I replaced the gasket of timing distribution which led to the invalid of timing. Then I redo the timing and it works. Should I reset the timing?
liusigou
First two plugs are the same, third is different
When was the last full tune up?
Yes. The third plug was loosen when I was in the lake last fall. And I bought one and put it back. Then it works. I owned this boat for four years. And have not yet had it tune up
alldodge
I showed these to pics to the wife and she has never done any motor work and she sees a difference
liusigou
Are they ok?
liusigou
I have replaced the spark plug and motor runs more smoothy. Thank you everyone.
dubs283
I do not
Possible that was a reason for poor runnability
Based on the other pics of cap, rotor, points, etc I'd say OP is due for a full tune up
lots of oil on the plugs - that indicates blowby
the one plug is missing its electrode indicting
there are bits of aluminum on the electrodes indicating the timing is off
being points, you have to set dwell before you set timing. so file the points, set dwell to about 30 degrees, then set timing.
