My charging system is so messed up what should I do?
samocamo123
I have a 1986 Ebbtide Montego 170 and it has a 1985 OMC 3L sterndrive (302sthrcom) and I thought the alternator was bad as the battery only read 12V so I bought a rebuild kit and then rebuilt the alternator (brushes, regulator, diode trio, and front bearing) and put it in. I put on the muffs and started the engine to noticed the voltage is still 12V, so I check the voltage coming straight out of the alternator and it shows 19.92V, what should I do? It also seemed to spike to nearly 60V one of the times I tried, but I may have just did something wrong.
bruceb58
Sounds like your alternator output isn't connected to your battery.
If so, you likely wiped out your regulator as well.
samocamo123
So are you saying running the alternator without being connected to the battery could have killed the regulator?
That would kill the alternator immediately. If it was dark, you would have seen the blue glow of the alternator going into melt down
Make sure the alternator is connected to the battery
I'm pretty sure the wiring is bad or something, but will rebuilding the alternator fix the fact I ran the alternator without the output connected to the battery?
it may, however you need to check the windings as well. take the alternator in and have tested. and fix your wiring
samocamo123
It seems to stay around 14V without changing anything once I fixed my wiring, also autozone wont test the alternator because the part number isn't in their system.
Go to a real alternator shop.
14 volts is normal whan connected to a battery
