my chrysler will not start
pilot7116
i thank i have like a 72 or 73 chrysler 75hp.<br />i have tryed to start but it wouldn't we cleaned the carbs all 3 and checked the plugs i not sure if am geting any fire i get 12v at the white wire on the dist from the box. the points are ok it poped one time but never ran is there any thing i can do or do i need to take it to someone????<br /><br />oh last time it ran 1983
moderator1
Re: my chrysler will not start
need all the help,<br /><br />I'm moving this to Chrysler/Force questions. I think the experts there will help.
seldont
Check the obvious things first. Have you checked the compression? Are you getting a good clean spark? If so is the ignition timed close to specs? Are the plugs good? After sitting that long are you using a fresh gas supply and is the fuel filter clogged. Is the fuel pump working or could the diaphragm be dried and cracked? If you have a good spark and the timing is close I would use a 50:1 gas/oil mix and squirt into the carbs and see if it will try to fire on that. That is what I would try first. Hope it helps.
The Marine Doctor
need all I can outline a test for you to test your powerpack.<br /><br />TMD
force01
Need,<br />Sometimes when the motors sit they will develop condensation/oil on the points take a clean white business card (make sure your points are not on a cam lobe)and run your small strips of business card through the points a couple times until you can not see anymore dirty traces on the card. then put it back together and see if it will start. good luck, bret<br /><br />If you need further assistance please email me @ forcepower01@yahoo.com. thanks,Bret
pilot7116
i am getting fuel but no spark how can i test my box and coil to see that they are working the whit wire coming out of the box to the distubuter has power???
