My computer problem
puddle jumper
My computer will not alow the internet to load up in my profile but in my daughters profile it works just fine.In my profile all of my other programs that use the internet work just fine but not the windows internet explorer.
Im using widows xp2000 programing and both of our profiles are on the same computer.
I hope some one has an fix for me becouse im not much of a computer teck.
thank you
i386
Re: My computer problem
This could be a tricky one.
In your profile, does IE fail to launch or it just won't display pages after it launches?
puddle jumper
The internet explorer fails to launch and i always get an error message saying it has become non responsive.I then have to shut it down using the end now comand.Every now and then it will come up but when i go to give it a comand or a web site to find it freezes up and becomes un resposive again.Any sugestions would be greatly appreciated.Im driving my daughter nuts using her profile,like im going to see something she does not want me to see.hum
Plainsman
I'd delete all temp files, cookies, internet temp files.
Run anti-spyware programs (spybot and or ad-aware).
You could always create a new user and move you files to that profile
Because the program work for your daughter, the program itself seems to be OK. It's something with your profile I'd say.
puddle jumper
Eric i did every thing you sugested and it didnt seem to help.Even the new profile did the same thing as my profile.Im using telus security system has any one else used it and is it junk or good to use.
i386
Ok here's a simple test you can do...
Go to Start -> Run, then type msconfig and click ok
Change it to Selective startup and uncheck startup items.
That'll disable most of the programs that startup automatically. Reboot, and try your IE again. If it works, you can enable one startup item at a time until you can cause IE to mess up. You should be able to locate which program it is that causing the problem.
If disabling the startup items has no effect let us know.
puddle jumper
Thanks alot I did what you said and it didnt make adiffence but along with it there was a place that i could reset my computer to the settings it had before the problems came up and it worked.
I thank you two very much, you helped me understand my computor just that more.
i386
Well that's good. You might want to look in Add/Remove programs and remove anything that doesn't belong and then scan with a good anti-spyware utility. Having a good, up to date anti-virus program would be good too if you don't already.
