SteveinVA
- Dec 16, 2010
- 106
Ok hello all, was hoping someone could give me some guidance.
I got a donor 6hp Johnson. model # CD25R. Ser # J2909879 first off can anyone tell me what year that might be? Is it a 79? read somewhere the last two digits is the year.
So here whats happened so far. Got the motor cleaned it up with out taking it apart. checked the spark plugs, sprayed a lil starting fluid in and it fired right up. shifts fine and all. Took it out once without any problems, just running a lil rough (sputters ocasionally when cruising)and doesnt go fast at all. didn't get my boat on plane. I am using it on my 12ft fiberglass V hull. boat probably weighs around 650lbs total with 2 people in it. Should this motor get me on plane? Ok next trip out. motor starts up and gets us on are way. then stalls out probably 5 mins later and wont restart. pull the cover and after a few pulls starts running again, put cover on runs for a few seconds then stalls and wont restart. take cover off starts and I decide to ride with cover off. So we are cruising along and RPMS start to drop until it dies. I try the pull cord and the motor wont turn. So head back to dock with troller. Next day pull cover and break motor loose turning the big round thing on top( dont know what its called). decide to check compression and I have 50 psi on each cylinder, is that good????
Decide to pull the lower unit to check impeller and I can turn the impeller by hand on the shaft without the shaft spinning. UH OH pretty sure that is bad. the pin that goes in the shaft appears to have worn a groove around the entire inside of the impeller. As it stands now I have ordered a new impeller kit from here, and cleaned out the impeller housing and lower ger unit. Anything else I should give a look before I reassemble and try to start.
Thanks in advance for any advice I really appreciate it
