- May 29, 2003
- 19,678
... AR! DIL won it in a raffle and I am the lucky owner at a great price! Yeah! Can't wait for it to arrive!
16? RECON CARBINE
GII RECON
LIGHTER THAN THE ORIGINAL. EVEN MORE BATTLE READY.
DPMS GII RECON
DESCRIPTION
The 16? GII Recon is just as battle ready as the original .308 Recon, but weighing less means, you can run it at your next high round count carbine course without needing to bulk up your upper body first. 16? stainless steel bead blasted barrel, DPMS hunter gas block, 4 rail free-float tube, and MagPul? MOE pistol grip and stock.
RFLR-G2REC
SPECIFICATIONS
CALIBER: 308 / 7.62 Nato
LENGTH: 38?
WEIGHT: 8.5lbs
BARREL: 16" 416 Stainless, Bead Blasted - Mid length Gas
UPPER RECEIVER: Forged 7075 T6 lvl 3 Anodized, Teflon coated, A3 type
LOWER RECEIVER: Forged 7075 T6 lvl Anodized, Teflon coated
TWIST: 1x10
STOCK: MagPul? MOE 6 Position Collapsible Stock
FIRE CONTROL: DPMS 2 Stage
PISTOL GRIP: MagPul? MOE
FRONT / REAR SIGHT: MagPul? Front and Rear BUIS
FLASH HIDER: None - Advanced Armament 51T Blackout Silencer Adapter
HANDGUARD: DPMS 4 Rail Free Float Tube
16? RECON CARBINE
GII RECON
DPMS GII RECON
DESCRIPTION
RFLR-G2REC
SPECIFICATIONS
LENGTH: 38?
WEIGHT: 8.5lbs
TWIST: 1x10
