Beefer
- Aug 4, 2008
- 1,737
I finally got around to fixing the access panel to my fuel tank. It was soft when I bought the boat, and was one of those 'I'll get around to it' projects. As a quick fix when I first got the boat, I put 2 aluminum angle braces in it, and that worked well enough, but I wanted to do it right eventually.
I originally planned on using plywood, and doing it that way, but I read on another forum about a composite called Prisma Preforms, by Compsys. I called and got a sample and a price list, and after talking to Mike at Compsys about what I was doing, how the panel was going to be walked on all the time (it makes up most of the cockpit deck), we decided on their carbon fiber reinforced planks, in 3/4" thickness.
Grand total for the planks was $56, and they even cut them to length for me. The planks are essentially a dense flotation foam that is glassed on both sides. Even though I didn't have to cut them to length, I did have to cut out the holes for the two deck plates. To cut them, I used common scissors, and my Leatherman for the thicker areas.
The planks were really easy to install, and the panel is solid as a rock. I don't have to seal the screw holes or the deck plates, as the planks can not rot. Overall, I'd say this was easier then if I had used marine plywood, and my total cost including resin and brushes was $110.
So, without further ado, here are the pics, starting with the panel before I started, up to the completed repair. 14 pics, so I probably have to do it in 2 posts.
1 - The panel in question
2 - The back side of the panel cut off, exposing the rotted core material
3 - A closer look at the core
4 - Coring removed. What a PITA it was to remove it, too!
5 - Half the planks installed on a dry fit
6 - All the planks dry fit
