MOdel 115ESL73 which is a 1973 115 hp. Problem is when I put engine in gear, forward or reverse, it dies. I have done the following: rebuilt carbs, replaced fuel pump, replaced power pack, installed new plugs, checked for spark on all four plugs, checked carb linkages, checked choke set up and checked timing for TDC. Now here is the strange part: If I disconnect the spark plug wires on the bottom two cylinders, the engine will start and idle on the top two cylinders. If I disconnect the plug wires from the top two cylinders the engine will not start or idle on the bottom cylinders even with spark on those plugs. I am not sure how strong the spark is on the bottom cylinders only that there is spark there. HELP PLEASE if you can. Thanks, Mark
