I figured that since I've done so much lurking around here - soaking up all the good info - it was about time for me to post some stuff about my current project. Last Sunday I took a road trip to pick up this baby - A 1981 Johnson Workhorse 25HP model number J25RWCIM
Seller indicated that the powerhead was rebuilt a few years ago - bored 0.030 over, with new pistons and rings. From the apparent compression, and the minty-fresh appearance of the head gasket, I have no reason to doubt him. Planning to run a compression test to see where we are today, but I expect that it will be pretty good.
Starboard bracket was cracked but I've secured a used replacement and got it bolted in place.
One of the interesting features of these models is that they have side fins on the gearcase housing in addition to the skeg. One of them was broken off, but the piece had been saved, so I had a local welding outfit weld it back on. Needs a bit more sanding but I think it should paint up good as new:
