artificialreef
- Feb 21, 2009
- 504
Afternoon folks. First water pump service attempt on a Mercruiser one drive R (1983 attached to a 470). I replaced the impeller and put in a new housing with all the gaskets, Orings and seals. Assembled back together and rigged up a pressure tester. I plugged the top vent tube hole with a bolt and oring, placed the testing rig on the drain hole and proceeded to pump. It would not rise at all and i could hear wind coming from the cavity where the water tube and drive shaft are. I dont have the prop on, outdrive is off the boat on a stand. Is there a common newbie mistake i could have made, everything looked pretty straight forward. Is it that easy to damage the seal where the watertube slides into the housing? Any help would be appreciated. This planter has not seen the water since i bought 2 1/2 years ago.Does'nt need anything major. Just an owner that knows marine service. I am not so bad with automotive but have alot to learn in the marine realm. Thank you folks.
