Ok, I am stumped with this one folks. My yamaha C115tlrx gets on plane and after a couple of minutes the motor seems to bog down and loose power. Here is why I am stumped. Compression is good, carbs are recently rebuild, fuel lines from tank to motor are brand new marine lines, brand new anti-siphon valve at tank, which is a separate question I have, will PS below. Brand new fuel pump, pick up tube was a bit kinked but I straighten it out, screen was clean, full gas tank with rec 90, and oil. Brand new gas tank vent, I can hear and feel plenty of air coming out when fueling. Sometimes it runs great, others it has the issue. I tried running with the fill cap loose to make sure the tank was venting. Still did it. It's not overheating, and got strong pissing. The water separator was a bit corroded inside but to debris came out when I drained it. Getting new one tomorrow. The only thing I have left to replace is the quick connect at the engine, which started to leak when I primed it, but that only started after i got home and flushed it and messed with it to try and find the culprit. In the water today it did not leak at all. Anyone have anything else I may be missing? Thanks.
P.S. When I replaced the anti-siphon valve, the old fitting was completely hollow, no ball inside. My question, do some boats have the anti-siphon with the ball inside, and some don't, or do all boats have that? I was told that without it gas would return to the tank after planing off.
