f_inscreenname
- Aug 23, 2001
- 2,591
What dose it mean when you get blue areas on your prop? I use a left hand bronze ocean racer (very small solid hub) 15 1/2 X 21 cupped prop on my Volvo 270 and I have noticed some blue areas on the blades. It is the same color blue as when you start to heat a piece off steel with a torch. They seem to go away after a day or two of sitting in the driveway. Do I have to much slippage or something going on? I have never noticed this on any other prop I have used. I even had a right hand 15 X 21 cupped prop made of the same material (bronze) but it looked like a standard prop for a Volvo 270 (large hub) on the boat and I never seen anything like that. When I changed over to this prop last year I did notice that I lost a couple MPH but with the left hand prop it steered a lot better then it did with the right. With the right at high speed you would have to yank on the steering wheel to get it to turn but with the left it was like having power steering. I thought the lost mph was from the prop having less torque just because I changed from right to left but now I starting to think the prop isn't hooking up right.<br /> If it matters WOT is 4700 rpm and I see it at least before I come back to the ramp.<br />
