My SEAFOAM experience
davejohnson
OK, veterans. Need help.<br /><br />My motor: '78 Merc 900 inline 6 (#5034807) I just got it this summer. Yes, I'm a rook.<br /><br />Runs great, better than great, at 25% throttle upwards. But this motor stalls at idle speed *every time*. I changed the plugs, rebuilt fuel pump, put in brand new fuel line, bulb, and plastic tank. No fix. Gummed up carbs, right? Maybe. Old-timer at the marina says (what I gathered from behind his terbaccy) something about the carbs getting gas at idle through little PORTS, and through JETS at speed. Anyway...<br /><br />So, after reading testimony after gushing testimony about SEAFOAM carb cleaner, I plunked down $12 for two cans of the non-aerosol. This morning, I went out, launched Ol' Creaky (antique wooden Thompson) and warmed her up for a few minutes. Then, I switched lines to the temporary tank in which I had prepared 1 gallon of gas/oil and an entire pint can of SEAFOAM. Let her run for 15 minutes, then shut it off. Waited 20 minutes. Started again, and yes, the motor did smoke a bit, about 30 seconds, but the smoke was white, and not the rock-n-roll billowing smoke that I have seen described here. The smoke died out. I let it soak another 15 minutes, then started on the "gas/oil only" tank, 30 seconds of smoke again, and ran about the lake at speed to rev out the yukky stuff (hopefully).<br /><br />After 30 minutes or so, thought I'd test the low-speed put-putting, and dammitt---it still stalled. I'd bring it to idle. Little sputtering. Advance throttle ever so slightly, dead. Start again, idle high for a minute, advance throttle slightly...dead. Now if I push throttle forward abruptly, it hesitates for a second, then VOOM! Out of the hole like a rabbit. Back to the dock, I stall/started back onto the trailer. Square one.<br /><br />Now, I *did* load it up with the gas/SEAFOAM mix before I put it away today, and will go out tomorrow, with hopes not so high, and try everything again. But please tell me: did I not do something correctly? Should I have necessarily seen some degree of performance improve? I'm a bit daunted at the thought of tearing out those THREE carbs and cleaning them (properly) but is that in my future?<br /><br />Sorry this is so long. Thanks for any thoughts.<br />Dave
JasonJ
Re: My SEAFOAM experience
Sounds to me like you need to adjust the idle jets on the carbs. Try counterclockwise (I think)in 1/2 turn increments until it idles in gear. It seems like I had heard/read somewhere that running the middle carb a bit more rich than the others helps idle and off idle response, but I could be on crack. Hopefully Clams will chime in, he lives for inlines. I also think he has a tutorial on adjusting inline six idle issues on this forum. Good luck...
rolmops
I think you got a few things mixed up.<br />You can use seafoam to decarb your cylinders.You must either put the seafoam in a spray bottle or buy a spray can and run the engine on "earmuffs" while spraying the stuff into the carburators.Then you spray in so much that you actually stall the engine.Start it up 2 hours later and the cylinder gunk will come out.<br />For your carburator cleaning you can just dump some in your fuel tank and it will sort of clear out your carburator much like any other carburator cleaner.What the old guy said from behind his tobacco is right.He may also have said something about adjusting the idle needles in the carburators.For that you do need a manual,which you can get by clicking on the link at the bottom of this page.
dicktaber
If the carb internal passages are gummed up, neither Seafoam nor any other "easy fix" will work. Carbs "may" need to be removed (one at a time, if possible), and thorougly cleaned. Many more threads here to help you with this. Remember that the idle passages (both air and fuel) are the smallest in the carb and therefore the easiest to get clogged up...
Clams Canino
If you remove the three Idle needles and shoot the holes with carb cleaner you might blow them clean. Then Reset the needles to 2 turns out and go through the idle procedure. <br /><br />Timing and sync may be an issue too...<br /><br />-W
Kenny Bush
Are we dealing with a good balanced powerhead....?
