erikgreen
- Jan 8, 2007
- 3,105
Hello all -
I have an old pre-alpha drive on my boat that has seen better days. It holds pressure well, and the water pump works, and I take care of it as best I can, but it had a major problem I had to deal with this spring. When I had an accident with the boat before my rebuild, one of the things that got goofed up was the skeg on the drive unit. It got mostly snapped off.
It snapped off so close to the gear case that a skeg guard was out of the question... most of the commercial ones require a certain amount of remaining skeg.
Now that the boat is rebuilt (only things left original are the drive, which except for the skeg was in ok shape) and the hull fiberglass, I'm using it on lake superior.
I use the boat mostly to run a side scan sonar unit, and I need to be able to drive very slowly, usually idle only (and I got into the wind to go slower) so I have to be able to steer in a straight line. With this boat, which is a 21 foot 2.5 ton lady, I had a heck of a time steering at low speed without a skeg.
I tried having the skeg welded last year, and it lasted about two months. One windy day I came into the ramp and the boat blew sideways into the concrete and stuck. No problem except the wind and some small waves pushed the skeg exactly where it was weakest, and it snapped off.
This actually left slightly less skeg to work with since the welding took some more metal off (grinding to get to good metal) and there wasn't enough uncontaminated aluminum left after it broke again to do the job cheaply... it would require a complete disassembly of the lower unit, shimming with a throw-away set of internals so it wouldn't warp, then re-welding after cutting off more dirty metal with a chance of breaching the gear case, requiring more work. If anything unusual happened during the welding, it was sure to cost more than just buying an SEI SE-106 lower.
But with all the stuff I've been doing I'm short on cash. So, I decided to give repairs a shot myself. Here's the before pic:
My plan was to cross drill holes for small bolts across the remaining skeg bits, then construct the skin of a skeg from two pieces of heavy gauge aluminum sheet cut to shape. Then I'd weld the aluminum together with one end open and shimmed to the right width.
Once the aluminum was welded I'd put it on the drive, clamp in place, and drill the through holes.
Then I'd bolt it on, using stainless bolts, and trim the bolts to size. I'd use lock-tite to hold the nuts on.
Following that I'd fair it with a mix of epoxy and chopped fibers, and a final top layer of glass microbubbles in epoxy, and sand.
Finally I'd coat it with aluminum primer and spray paint it black.
So, how well did it work? I'll show you when I get home tonight... I could have sworn when I started typing this I had both before and after pics, but I guess not :\
I took it out this last weekend for a test... it worked flawlessly, turns were fast and responsive at high speed, and the boat was easily controllable at low speed.
Erik
Erik
