Ok guys,<br /><br />sorry to be a hog here but my suzuki dt30 1989 is overheating at idle. If I start running the motor it doesn't overheat. If I go WOT it doesn't overheat either. But if I'm idling for more than a minute the pee stream gets kinda flustery and then the alarm goes off. I feel the head and its HOT. However if I start the motor, then soon after take off and run about anywhere other than idle the motor alarm does not go off. I know I have to get that infrared thermometer. I will I promise. But I do believe the motor is too hot at idle and possibly a little on the warm side while running. I've replaced the impeller and wear plate. What I haven't replaced is the oil seal on the pump housing. When I put the motor on muffs the pee stream is peeing like a horse. I know the water pump isn't putting off enough water at idle. What else could I be missing? Thanks again.<br /><br />Adam
