Mysterious grey powder on aluminum boat
polk county
I have an aluminum john boat that is missing a lot of paint from years of use. I noticed that objects such as coolers, gas tank and dry boxes all have grey powder deposits where they slide around on the floor of the bare aluminum. The powder looks like graphite powder being a grayish black in color. It feels very fine and will not come off with soap and water. Is this my aluminum boat shedding metal? Any ideas
Thanks
ondarvr
Re: Mysterious grey powder on aluminum boat
Aluminum will come off on most anything that rubs against it .
shrew
Aluminum oxidates when exposed. I believe that this creates a protective barrier on the surface of the aluminum.
rbh
Aluminum oxidization is usually found under painted areas where the water got in and sat, kinda like aluminum rust, and it begins to pit the aluminum.
I would clean the area till it shines or is clear of the oxidization, then hit it with a aluminum primer to etch the metal then paint over it to seal it if you are not going to leave it bare.
Fleetwin
Correct and completely normal, to a point.
H20Rat
aluminum rust... entirely normal.
acarter92
Thanks
It's probably a mixture of the aluminum rubbing off and then oxidizing (rusting).
You could put something over it (carpet, rubber, etc...) Or just let it go, I doubt it will really hurt anything...
Austin
