Mystery Floating Metal Ring Top of Shaft Housing
getoutdoors
MERCURY 2005 150L 150H V6 OPTI. Replaced impeller, drive shaft will not reinsert due to metal ring floating at top of drive shaft housing. Other owners have used long items to apply grease to keep in place and inserted shaft. I want to know what I should do. If I need to fix can it be done by removing drive shaft/exhaust housing? Thank you!
Grub54891
? How about a pic of where the ring is, so we can figure out what you are talking about.
Faztbullet
Uh oh.......thats the driveshaft seal carrier.Will need to pull powerhead and reinstall with Loctite.
