I recently purchased an old Johnson outboard motor as a fix-er-up, and I'd like to identify it. I can tell where the ID tag used to be, but it's clear that it's been gone for many years. The person I bought it from claims it's a 90 HP, but he got it from someone else (who got it from someone else...) so I consider that info suspect. The motor was on a '67 model boat, and by the look of the transom, it's original, so I suspect the motor is a late '60 model. <br /><br />The cowling says it's an Electramatic Super Sea-Horse. The cowling itself is white, and the drive section is black (if that helps). I've got the motor torn down, and it's a 2-cycle V-4 with 3 7/16 D pistons with about a 2" stroke. I'd like to identify the motor's horsepower, model, and year if possible. I'm going to need a lot of parts to get it running again, and gaskets are hard to buy if you don't know what you're buying them for
.<br /><br />Thanks in advance. If I can provide any other info please let me know. As I mentioned, the engine is completely torn down on my work bench, so everything is accessible. I've got detailed digital photos of the engine while it was still on the boat, so if that will help I'll build a web page and post them.
