I posted a while back regarding my boat dying on the water. It shut off just like someone turned off the key. Well I figured it was a spark issue/ignition issue. Nope. Spark from coil. Not as strong as i'd like but the battery is a little low.
I then checked for fuel. No fuel coming out of the carb. Carburetor was dry, pumping nothing. Disconnected fuel hose at the carb, and it pumped fuel like crazy. So fuel was getting to the carb, but not into the manifold.
So stuck float or blockage right? Nope. Took the carb out, replaced some gaskets, hooked it up to fuel, pumped the accelerator pump.... and a nice Y shaped stream of fuel came out.
I am at a total loss. I have no idea what is wrong. I thought the pump was bad, but it obviously isn't. Any ideas? I also tested the fuel for water, and none in it.
