Mystery Prop
Wingedwheel
I've got an older two-bladed brass prop that I picked up at a garage sale. I have no clue about figuring out the #'s stamped on the hub. Can someone identify this prop?
Chris1956
Looks to be a thru hub exhaust-type prop. Mercs used to have 2 blade props. Perhaps it is one of those from the early 70s or earlier?
Frank Acampora
Well, if it looks like a duck, has a bill and webbed feet, it probably is a duck! It has 15 splines and has the number 19 stamped in the hub. It is bronze and Mercs did at one time have 2 blade props. It is probably a Mercury or aftermarket Michigan 2 blade prop for the larger engines like 100 or 115 (1000 or 1150). Probably a 13 X 19. Since diameter would be nominal simply measure across both blades and don't be surprised if it is different from 13 inch. It may have been repaired; there appears to be a prop repair shop letter stamped in the hub.
You can call Mercury customer service and get full information on the prop from the numbers on the hub.
Lots of props have repair shop invoice # stamped on them...----Any numbers on the side .----Pictures of complete prop ?
fishin98
We had a 1963 Merc Mark 55a with a two blade brass prop on our StarCraft when I was a kid back in the 60's and 70's
