Name that boat part
*EdC*
OK Guys,
I called this part a "rub rail" and was quickly corrected. I was told the rub rail is the rail around the boat at the deck line. Could someone PLEASE tell me what the real nautical term is? :confused:
Thanks,
Ed
jusfloatin
Re: Name that boat part
I say it is a rub rail that was added by a previous owner for loading it on a trailer or a boat lift.
tashasdaddy
i is a rub rail, added probably to keep the boat off the dock, that was lower. say a floating dock. yes it was added, as it does not match the other rub rail.
Ayuh,....
That's a Rub Rail/ Spray Rail...
Starcraft has used them for Years....
Btw,....
Reduce the Size,+ then Repost your Pictures....:mad:
Nobody likes to have to side-scroll to answer your Questions,....
And there's No Reason for it...
*EdC*
Pretty sure it's original. It's missing it's vinyl insert however.:(
D
DJ
Guest
Bond-o got it.
Spray rail or secondary chine.
Two purposes. Spray control and stiffens side.
*EdC*
Thought a spray rail was located at the bow. Near the waterline. :confused:
Mark42
Yep, that is a rub rail. Check out the MFG in my signature pics, it has one too, and its OEM.
Ned L
Spray rail, that's what they were first installed as back in the 1930's, 40's, & 50's.
sschefer
Technically, it's a type of permanent fender and so is the rub rail. We all know we can buy temporary docking fenders that we throw over the side to keep our boats from being beat up, your's is just a permanent.
A spray rail would need to be located more near the waterline if it was going to be effective at speed. My 91 Starcraft has a spray rail that the manufacturer calls a lift strake.
kaferhaus
I was always told that it was a "high water fender"... common on boats sold in areas where there was significant tide movement.
Don't see many down here as we only get about 1.2ft of water movement during normal tide cycles.
