Name That Noise
jeb6294
Any thoughts what this whirring kinda noise might be? 175hp 4.3 seems to run fine, temp and oil pressure fine. Just a constant whirring kind of noise.
achris
More fish than mountain goat
Pull the boat out of the water and run it on flushers. Move the steering full lock left and right. Noise changes, uni joints. Remove the drive and with a water hose in the bell housing water inlet, is the nose still there? If so, engine problem. If not, a drive bearing, or the gimbal bearing...
dubs283
Can't hear much but a guess, as stated, would be gimbal bearing/u joints worn, damaged, loose, etc...
Time to pull the drive and inspect
