NAUTIJOHN TABS FOR STRATOS
jk1162
LOOKING FOR TRIM TABS 1986 STRATOS, 1989 225 YAMAHA, 6" HYDRAULIC JACK PLATE, 80+ MPH. BOAT HANDLES EXCEPTIONALY WELL AT MID AND HIGH SPEEDS; NO PORPOSE, CHINE WALK, OR STEERING TOURGE. THE ADDITION OF THE JACK PLATE ONLY THREW OFF THE BALANCE ON GETTING ON PLANE, SLOW PLANE SPEEDS, (AND PORPOSE AT LOW SPEED, UNLESS TRIMMEND ALL THE WAY IN). WHAT SIZE AND POUND WOULD YOU RECCOMEND. THE 1986 WAS MORE OF A FLAT BOTTOM HULL NOT A REAL DEEP V.
jk1162
Re: NAUTIJOHN TABS FOR STRATOS
THE BOAT IS 19' LONG. FORGOT TO ADD ON ORIGINAL POST.
Jdeagro
iboats.com Partner
JK1162;<br /><br />A bout with that top speed capability is going to require some carefull tuning. I would start with the MT1080-60. What we do not want is to create too much bow pressure at top speed which will slow the boat down. The balance is an issue because of the motor and the off set. However once tuned correctly you should have a very smooth running boat with no planning issues.
