clarifydeveloper
- Aug 26, 2008
- 11
I have been fishing a stretch of the Colorado River that divides Arizona and California located near Blythe, California. I have fished this area for a couple of years mostly from a shallow draft aluminum boat with a small outboard but have recently begun using a larger 19ft i/o. This boat runs considerably deeper.
This stretch of river fluctuates seasonally and daily depending on the amount of water released from upstream dams and also drained off for irrigation and the like. There are numerous sand bars, rocks, shallow flats, etc that can change frequently. Some places may be safe to run across in the morning and by lunch leave you stranded, but there IS a channel that is navigable year round, its just not marked. Boats the size of my 19 footer DO use this area, though a lot are jet boats. I fish there maybe once a month so I am guessing some of the other guys have been fishing it for years and/or very often and have miles of river memorized.
I am wondering if a gps navigation unit would help me? If i slowly and safely find a route down the river will a gps unit work for me to rely on to travel back? I am not familiar with marine gps. I have a gps built into my phone but that isnt sophisticated enough for river navigation and also fails to load the maps due to signal failure in that area. If a map is required for a marine gps I am not sure one would be available for this part of the Colorado River.
I am looking for some way to map out miles of channel so that I can just follow the gps unit, day or night, with confidence that I am on a safe path. I realize this doesnt account for things that may have washed into my path, like logs and such, but for the most part if I map it at the lowest water level then I should always be in good shape.
Please let me know your thoughts.
thanks
thanks
