Need a Johnson/Evinrude Lower Unit 50HP
franciscolau
I have a Johnson 1982 50HP Model No. J50BELCNR. I need to replace lower unit. I know that the assembly No. for the lower unit is 0393136 which was use on several johnson/evinrude engines from 40 to 60HP and I think from 1979 to 1985. Questions are:<br />1) how much is the fair price for a used unit, not rebuilt?<br />2) are there any other assembly numbers that can fit this engine.<br /><br />Any help will be greatly appreciated.
MCM
Re: Need a Johnson/Evinrude Lower Unit 50HP
Welcome to the Forum lau,<br /><br />Here is a list of motors that used that gearcase, p/n 0393136 was superceded to p/n 0433572 both of which are NLA. BRP and Ishopmarine list a p/n 0392196 as a gearcase and bearing assembly that will work on that motor.<br /><br />Here's the link to BRP'S web site where you can cross reference the p/n's, using the advanced search feature.<br /><br /> http://epc.brp.com/default.aspx?brands=ej&lang=E <br /> <br />Maxrules.com lists a new gearcase for $1500 + and a remanufactured for $1250+<br /><br />Ishopmarine lists p/n 0392196 at $955.30, Try here at IBOATS or there's always Ebay for a used one.
franciscolau
Thank you for your help. It was very useful information. Merry Xmas. Lau
Fishone
Originally posted by lau:<br /> I have a Johnson 1982 50HP Model No. J50BELCNR. I need to replace lower unit. I know that the assembly No. for the lower unit is 0393136 which was use on several johnson/evinrude engines from 40 to 60HP and I think from 1979 to 1985. Questions are:<br />1) how much is the fair price for a used unit, not rebuilt?<br />2) are there any other assembly numbers that can fit this engine.<br /><br />Any help will be greatly appreciated.
Fishone
Hi Lau. I think the lower units went from 1979 to 1988. I can look if you are interested, if I have anything that can help you,
bradleeson
I used "Twin City Outboards". I got a rebuilt lower unit for my 1982 evinrude 50 for about $650 with core exchange. I received the unit two days after ordering it, and used the box it came in to ship out my core.
Faztbullet
The 1976-1988 40/48/50/55/60 will all interchange with each other. The 1989-1992 are different as are the 1993-2005.
ozarkglen
I found a salvage yard near my local area lake that specilizes in older outboards. I bought a lower unit for my '85 60HP for $50! I bought a seal kit from iboats and used the parts from the 2 units to build 1 good unit. Been running it for 3 years! You might want to look around before you spend a ton of money!
tx1961whaler
The original post was from 2005. He probably fixed it by now! :)
Good parts info though.....
manjaki
Hello everybody!
I have the same engine Johnson 1982 year 50 hp model: J50BELCNR, need to change lower unit.
Can I buy lower unit from this engine E40ELCCS / 40 HP.
Did it fits to my engine or not ?
Thanks for replies.
Bob_VT
Hello everybody!
Thanks for replies.
Welcome to iboats.
Please start a new thread with your question since this one is old.
TY
