Need a new shifter for a 1978 Mercrusier 470 Fiber Form Sports man boat
bob84124
I have a 1978 Fiber Form Sportsman and the shifter is missing the neutral switch. Very dangerous when starting the boat if the shifter is not in netural position. What other unite can I replace this with? The motor is a mercruiser 470 inboard. any help is appreciated.
GA_Boater
We have a problem.
This same picture was used in another thread on Friday. What are the odds of two members with the same problem using the same picture of a 1978 Fiberform Sportster.
Explain quickly or it's the door!
kenny nunez
Are you sure that there is no switch, it may be there without the wires attached. Are there yellow/red wires going to it? If it is there it will look like a hex bolt with 2 small screws. Can you remove the control and take a picture of the backside. I have installed that very same model several times. It uses 3300 series cables. If you replace it it will have to accept those same cables.
