need a part 4 trim hoses and can't find it
I have a 1975 65 hp merc with trim. I need the distribution block that takes the 4 hoses from the trim rams to the 2 hoses from the pump. I saw a pick of it but no part number. Any help would be great. Stacey
Faztbullet
Re: need a part 4 trim hoses and can't find it
Hoses go straight to pump no block unless its a inboard.....
It has two rams and 4 hoses and it's an out board. Pump has 2 hoses.
Anybody else that can be of help.
Faztbullet
Somebody made that as its not a factory OEM part,as the correct pump would have connections for all 4 hoses....
Laddies
Banned
If it's a square Prestolite pump it has the Mercrusier shuttle valve on the bottom of it (held on with 4 1/4" bolts) that needs to be changed to a manual release valve with 4 hose connecters. If it's a later pump with only 2 outlets then you will have to go to a auto parts store and buy 2 tees and a short hose to adapt to what you have and omit the manual release valve.
