need a prop minnkota
tdglau
I have an old minnkota model 35. It has the old style plastic prop and I am needing a new one. Can anyone point me in the right direction?
tdglau
Re: need a prop minnkota
Its way older than that prop. If it were only that simple. this has the small central shaft. The center portion is maybe 1" across. The prop has a shear pin that you bend over to hold it on the shaft. The motor was bought around 1979 or so.
