Hello all,
I have a 25ft 1991 Bayliner 2556 Ciera Flybrige with small block v8 Mercruiser 5.7L engine (with 1150 hours) and Alpha One Gen II outdrive. The boat is heavy ~6000lbs, plus 500-700lbs of fuel and usually between 6-10 passengers (girls).
The current prop is a 3 blade mercury aluminum 15.5diameter x 15pitch.
Over the past few seasons this formula has worked well for me. This year the performance is degraded.
For example, I used to hit WOT at 4400rpm at 28mph with 8 people onboard...This was great!
This year with 7 people onboard I can only get the boat to 3900mph at 23mph( it feels strained at that RPM too). And with 8 or more, no plaining at all...
Getting up on a plane even with JUST me onboard use to be to be faster last season. This season, much slower, like taking over 20 seconds and at lower top end MPH 28mph vs 30ph or so before.
So basically performance has got worse....
Why?
Concerns:
-Visually inspected prop. it looks smooth and clean, no dents. Do these aluminum props wear out, mine is old?
-I cleaned the hull. there wasn't much algae, just a tad (it's in a lake)
-Bottom painted the boat 3 seasons ago, some of the paint was flaking off, but most was in tact. Could this slow me down that much?
-Engine: changed the spark plugs, distributor, etc. The engine is running nice and smooth, sounds great, but it is 20 years old!
-Ethanol change in gas from last year...could this steal my performance.
I'd like to get the boat back to moving fast with lots of people on board.
Is there a prop that can get my heavy underpowered boat on a plane.
I would accept giving up on the higher speeds (>28mph) for a quicker planing experience at lets say (25pm) with 8 passengers on board.
My prop guy suggested a 16"x14 quicksilver aluminum 3 blade as the current 15.25" x 15 have might have too much pitch for me to plane with all this weight. But I am concerned about moving to larger 16" diameter.
I've also read that a 15.5" x 13 pitch has been used alot in my boat. But I am concened that 13 is not enough to keep my boat planing as it will fall of if I don't keep it about 22mph or so.
Suggestions?
Thanks again!
Why?
Concerns:
Suggestions?
Thanks again!
