Re: Need a quick tip
You drive out the two press fit locating pins. Then, pry at the recessed pry points diagonally on the blocktop and bottom. Be certain that ALL case screws are removedincluding the two that go in opposite the others, behind the starter mount. The two lower fillister head screws must also be removed.
