Need a source for 3 inch grommet (maybe its not called a grommet)?
scott hamilton
I can't find these anywhere. Can anyone help?
Woodonglass
Re: Need a source for 3 inch grommet (maybe its not called a grommet)?
What's it for??
garzilla
What's it for??
Looks to me like some cabling of sorts passes through there?
I've made grommets like that from old truck Bedliners, and semi truck mudflaps before.
Turned out pretty nice....I think the mudflaps are better imo.
DustinJean
if its for something like a hose or wiring to run through go buy some vacuum hose at a local auto parts store and slit it down the center and fit it over the aluminum all the way around to get it by until you can find a fitting, but it looks to be plastic so doubt they would call it a grommet but im not sure what they would consider it or where to buy one
MichaelP
Its kinda hard to see but I have an extra one of these from my resto. I can get dimensions if your interested.
scott hamilton
It protects motor wiring from chafing where the wiring passes thru the aluminum splashwell. I'm suprised they are not more readily available. I would have been more careful taking them off. Thanks!
scott hamilton
maybe its called a passthru?
MichaelP
You can get reinforced rubber strips like the ones around the lip of the cuddy hatch, again at auto parts stores.
