Need a special tool for duoprop removal, i'm not sure which one ?
chiefshocker
I was trying to change the oil on this new boat, larson 270, volvo penta. I'm new to all this but see i need a specialty tool to pull the 2nd prop. I found two types, but not sure what class/type prop i have to match up to the tool.
Pic of my prop attached if anyone can id the correct tool that would be super.
jetmart
Re: Need a special tool for duoprop removal, i'm not sure which one ?
I believe it is this one, I have an DP-SM and it fits it.
Volvo Penta D F Duo Prop Wrench | eBay
Thalasso
You say new? New to you or a 2012-13-14? What drive is on it?
If it's the DPS-A, you need this tool.It works on the D and F series props
Volvo Penta Prop Tool Kit 3855516. US $24.99 on E-Bay
chiefshocker
1997, not sure what the drive is how do i tell?
HalfFish5087
It's this one. If you want to put yourself at ease before ordering check the engraving on the prop for F or D followed by a number. I bet you will. Also, I would order new o rings for the dipstick and filling/exit port.
chiefshocker
cool thanks i'll check in the am
bruceb58
I bought one and also made one with a socket on the top so I can use my torque wrench.
bruceb58
Make sure you also buy the adapter that makes it easier to pump the gear oil back into you drive:
VOLVO 3855932 -
dypcdiver
This is mine it has been working for 14 years and cost $5 approx. Socket is same size as the rear prop nut, makes sense.
chiefshocker
I like the DIY ones, not much to them, might be quicker to just make one. Thanks again.
chiefshocker
What diameter pipe are your tools?
bruceb58
mine is at my brother's house right now. Will be a few days before I cam measure it.
Thalasso
Gear Lube Oil Drill Pump, 3 1/2 GPM - Seachoice 19191
$7.42
That prop nut looks like a F series
Prop tool on E-Bay is $30.00 and will fit the first time and your going to make one and have to fine tune it to get it to work properly?
Better things to do?
bruceb58
True...mine did take me 30 minutes to make.
chiefshocker
Its 2" and checked my prop as suggested, the number starts with an F, thank you.
