Hello Everyone,
This is my first post but been a member a bit and buy through IBoats.
I have a 7.4 Merc Inboard closed cooled with about 625hrs.
After we splashed for this season we took her out for a run and when she hit 2000 rpm start backfiring out of carb.this never happened last years. So, I changed fuel filters again, rotor,cap,wires and plugs, adjusted carb. Fuel was good, this is on port motor, starboard fine. The motor starts fine, idles fine, runs at 1900 rpm like nothing is wrong. Hit 2000 rpm and pop pop. I had a compression test done by marina mechanic a few weeks ago. found all cylinders at 145psi except #4 was 90#psi.
I didnt make them go further yet, I am gonna pull rocker covers off soon and check rocker arms and give a look. thinking valve problem thats the obvious.
lets here some thoughts and worst case
Thanks
Joe
Thanks
Joe
