Need advice on gauges problem
dellsboater
Pulled the guage assembly out to replace dash panel. Took pictures and reinstalled them. Tach works, trim guage works, rest will not read. Oil guage pegged at 80, volt meter does not come off Zero, fuel guage reads empty. Checked purple wire going in seris to each guage, have 12 volts. Have all purples going to P on back off guage. Have Black wires going to G, and have grey wire on tach, blue on oil guage, volt has no more wires except blk and purple. Temp guage has tan wire. Main ground on tach. All lights work in all guages. Any way to test each guage?
1988 OMC with Medalion Guages Four Winns
THanks
Barnacle_Bill
Re: Need advice on guges problem
Double check all your grounds at both ends.
Ayuh,... Test for 12V Between those 2 posts....
then figure out where yer Bad Grounds are...
dellsboater
Re: Need advice on guages problem
Have 12 volts between the purple and back wires, will check the posts
Ayuh,... On the Voltmeter,...
If you have 12V positive on the purple side of the gauge, 'n 12V negative on the black side of the gauge...
If it ain't showin' voltage, it's junk...
The oil pressure gauge should be 12V positive on the purple post, it should show Nothing, til the sender goes to Ground...
At Full Ground on the sender shows Max...
Ditto the water temp gauge..
Ditto the fuel gauge...
dellsboater
Have good grounds on both ends, still only tach works
dellsboater
So if I pull off the grounds, it should read nothing....right?
dellsboater
Update:
Went to Auto Zone bought a cheap volt meter, hooked it up worked fine. So I found a nice set of new gauges Teleflex Black Sterling on ebay for 100 bucks, did not come with trim or volt meter, re wired my gauges as these had the 4 plug back, my old ones had post. Hooked them up and all works now. Found the other two gauges also on ebay to match. Put the volt gauge in last night, still awaiting the trim gauge to arrive. All work, except lost cabin lights, suspect the switch may be bad, anyone ever heard of a three position toggle going bad? Am going to meter check it tonight and bypass the switch to see if it fixes the problem....
sw33ttooth
all switches can go bad :( id check connections since your in with all the wires doing the gauges also i have a 91 sundowner the fuse pannel directly below my gauges id check that every thing is still hooked up and fuses not blown lota wires in there easy to bump something off and no notice right off.
dellsboater
Well it turned out to be two things. The ground for the lights was bumped off when I put the dash back in, and a bad switch. I ran a direct line from the wire for the lights removed off the switch to the positive on the fuse panel. No lights, found the loose ground, re attached, then lights worked. I hooked back to original switch no lights. Tried another switch that was for the under bow cabin lights. Have lights. For know I will have it come on with the cabin lights. Thanks swtooth33...you helped me by chasing the loose ground on the panel. Mine is set up just like yours with the fuses right below the dash. I also have under bow, or cabin lights now. I bought some led light rods, they are 2-4 footers, and 2-3 footers. I am going to try them in the cabin and under the side compartments for more lights!
sw33ttooth
glad i could be of help, and even happier that its fixed now :)
