ronboonville
- Jun 6, 2012
- 287
I have a 12' appleby jon and a 5 hp clinton sea king. I centered the motor on the transom and with the swivel boat seat centered it is very difficult to operate. I think I should offset motor to the port. and remove the swivel seat and set on the bench to find the best spot to remount that seat. I don't really like using my left hand to operate the tiller so have considered doing the opposite. the motor seems like it is low on power so I was thinking it might be to low in the water. The vent plate is maybe 3 inches below the bottom of the boat, should I raise it? I would have to make something to raise the transom height, but I'm pretty inventive. as always I need help and usually get it here. thanks, ron.
Also if I can't get comfortable and be safe I'll probably get an electric trolling motor around 40 lb. thrust.
