Need advice on power tilt for 1979 85 HP V4 Johnson
andreipou
Hello,
I was working on restoring this motor (85ML79R).
It is ready to go on the boat, but it has just tilt assist cylinder, so it is manual tilt.
I was thinking about adding power tilt.
There is a bunch of them on Ebay from $100 to $300.
I do not have experience with Power T&T, so can anyone advise what to look for this motor?
Thanks.
flyingscott
1979 up until around 1990 will work, anything from a 3cyl to v6 will work. I would try to find a mid 80s 2 wire unit that uses the smaller relays. Try to get as much of the harness as possible especially the relay box. They are a direct bolt in so installation is fairly easy. Either take the motor off of the boat or pull one of the transom brackets off. you cannot use a Fast trac unit from a newer model they don't fit.
andreipou
Thank a lot for valuable info, because most of what I see for sale is FastTrac.
Motor is on a stand now. A little too cold to put it on now, boat sits outside.
The RC unit that I have now came with 1981 Evinrude (E50BELCIC).
Do not know if it is original, but it does not have T&T buttons.
Is there a way to get separate switch for T&T to work?
The 1980 accessories book shows a trim tilt switch that mounts anywhere on the boat.
andreipou
Guys, do you think this will fit?
Tnx.
andreipou
As winter going close to the end I am back to boating projects.
I did get PT&T unit, relay and switch above.
PT&T unit has 2 wired: green and greenish\bluish one.
When I apply 12 V to them unit goes up and in revers wiring it goes down as supposed to.
The problem with it is that it came with 2 out of 6 mounting bolts broken and sitting in the body , so it will be the challenge to get them out, but this is different question.
What I really need help with is to figure how to wire this thing properly since it is not a "native" setup.
The switch has 3 wires: red\blue\green. I assume that red will take 12V and blue and green will go to UP and DOWN on relay.
The relay (pics below) has black wire (ground?) , double red cable, one light green, one dark green, and cable with 5 wires ( blue+white, green+white, red+white, white+brown, black+white)
How do I connect switch to relay and relay to the motor?
Tnx.
andreipou
Look like everyone is still in ice fishing mood ...
Hope someone can give me an idea on how to properly to connect PTT unit thru this relay.
Crosbyman
grenn blue drives the t&T by simply reversing polarity under relaycontrol
relays need battery +12 &grd and therest are control wires to the up down switch to flip polarity to the T&T motor
andreipou
Finally ran old boy on the lake today.
He is back to life, ready for striper season.
Thanks everyone who helped!
