Need advice -- rebuilding carb right now and have question.
JamesCoste
I'm rebuilding my 50 HP Johnson's carbs today since the motor runs great one day, funny the next, after sitting up for 4 years without running.<br /><br />Might as well eliminate junk in the carbs.<br /><br />I've got the carbs removed and am working on the first one. I've removed the float and am the step where it says "remove and discard all gaskets, O-rings or sealing washers in the carburetor body casting".<br /><br />I'm to the point where the parts I have remaining in my rebuild kit include 4 aluminum(?) metal discs that are slightly beveled on one side. I can also see where the carb housing has 4 similar sized discs on the housing that are now flattened.<br /><br />1) How do I remove the old ones?<br />2) How do I install the new ones?<br />3) Is this a crucial step in a rebuild?<br /><br />I'm using a Clymer manual. I appreciate the help.
JamesCoste
Re: Need advice -- rebuilding carb right now and have question.
Oops, wrong forum. Sorry.
