Need advice repainting nonskid
rdc54yty
I have a 94 Chris Craft Crowne 340 cruiser. The deck above the helm behind the windshield and top of the instrument panel is nonskid. Can't tell if the nonskid was molded grey gel coat at the factory (there's little paint edge discernible). The previous owner painted it (poorly) off-white and it flakes off easily at places. Other places it looks like the paint is still well attached. I need a process to remove/restore/repair the nonskid. I have the windshield off for restoration and it's now of never I think.
How do I clean up the nonskid if it's molded in the gel-coat? Honestly the grey I see looks pretty good, don't know why other than heat the previous owner felt the need to paint it.
TIA
Keith
Re: Need advice repainting nonskid
Ayuh,... Use a quality paint stripper, or maybe acetone....
Neither will effect the gelcoat below...
It might take a work-out with a brush...
Boater45
If you want to replace it....this stuff works great:
KiwiGrip Non-skid Coating
GREY (1 gallon, 4 liter)
KiwiGrip anti-slip marine deck coating is a revolutionary, safe, durable, non-skid deck treatment that comes out of the can with a thick, yogurt-like, consistency ? but spreads quickly and easily with our proprietary roller. KiwiGrip offers a beautiful, consistent, grippy surface. By varying the application technique, the texture can be adjusted from ?fine? to ?aggressive.? 2 square meters per liter (approximately 80 SF/Gal). Includes special roller cover. KiwiGrip Anti-skid decks Perfect for Do-it-yourself Projects!
*Rolls on quickly and easily
*One-coat application
*Cures in 24 hours
*Cleans up with soap and water
*Water-based acrylic polymer, non-toxic, no volatile solvents
*Easy recoat: Just clean the old and roll on the new
*No masking required!
Here is a link: http://boatbuildercentral.com/proddetail.php?prod=PACH_KW_gal_gry
rdc54yty
Thanks, I have a qt of Peel Away 7 around here somewhere. If the non-skid pattern is molded, do I need a nonskid paint too? Seems pointless. If not then what?
Boater45, believe me when I say with me masking is required...
Ayuh,... I'd think thin,+ sprayed...
The heavier the paint, the more wash-out of detail...
Or,...
If you can live with the color of the restored gelcoat,..?? Why paint it,..??
rdc54yty
Following up on cleaning off the painted gel coat nonskid. I did not repaint as the original grey gel coat looked good enough after stripping.
1. Used Citrus Strip (CS) to get the bulk of the paint off. Worked well for 95% of the paint. It softened the paint in under about an hour, outside temp ranged from 65 to 80F, sunny day (not ideal). Scrubbed with a plastic brush periodically.
2. Next, scraped off 90% of goo mixture of CS and paint, scrubbed the remaining CS first with a plastic scrub brush then lightly with a small brass brush on tough spots. Retouched and scrubbed tough spots with CS. Then washed off the residue with water and a rag. Let it all dry out a day after washing real well on final time. Be sure to get Citrus Strip ONLY on the gel coat, it'll soften PV-type plastics real quick.
3. Next coated the area with Aqua Strip (AS) because I wanted to leave it overnight and it seems much less aggressive than CS. Came back next morning and scrubbed again with both plastic and brass brushes. Keep it wet with a spray bottle, it seems to work better, the goo seems to reduce the effectiveness of brushing. AS seems safe for PV-type plastics.
4. Cleaned real well with water and a rag, a pain because AS is more gooey than CS.
5. Finally painted the area with FSR to get off little specks of paint which remained and even out the color (grey gel coat nonskid). Then scrubbed with water. Did the job but not perfectly. Only did one application as I ran out of FSR.
That's it. There are still a few areas where pain specks are visible but I'll revisit them throughout the season. End result - much better looking than the cracked painted mess.
And now I have a nice new powder coated windshield frame to attract the eye away from the imperfections in the gel coat.
Hope this helps. Prepare for a mess...
Happy Boating
Keith
