Hello. I am trying to replace the stator on my 40HP 1992 Mercury outboard and cannot get the flywheel to come off. I have th correct puller. I removed the center bolt, installed the puller by threading onto the flywheel and then tightened down on the crankshaft, but the flywheel will not come off. Any suggestions what else I can do? If I have tried tapping gently with the hammer but dont want to use alot of force. Also, should I be threading the puller completely onto the flywheel or just a few turns and then turn the center bolt down onto the stator?
any help would be much appreciated.
Thanks!
Thanks!
