Re: Need advise on Inboard purchase
Once you go straight inboard, you never go back....
<br /><br />Pitfalls... <br />Yea, a straight inboard might be a bit slower...<br />Exposed running gear is easy to tear up if you run aground, not so much an issue on a Penn Yan because of the tunnel...<br />Low speed (idle) handling and backing down is marginal at best.. Practice makes ya better..<br />Changing packing in the stuffing boxes is a bit of a drag (unless it has a dripless box), but usually not a big deal..<br /><br />The up side..<br />The engine's in the middle of the boat, where it's supposed to be.. Weight in the center, and the engine being low makes a boat much more stable because of the lower center of gravity...<br />Maintentce is easy as it gets... Open the engine box, everything's right there...<br />Engine noise is usually low..<br /><br />Things to look for..<br />Aside from the things you'd look for in any boat, rotten wood, electrical, ect..<br />Worn cutlass bearing (rubber bushing in the strut).. Time consuming, but fairly easy to repair..<br />Vibration.. Not necessarily a big problem.. May be as simple as poor shaft/engine alignment, or as bad as a bent shaft, or bent or poorly balanced prop.. <br />The hose on the shaft log should be checked for rot, and the shaft log itself along with all the underwater metal parts like the strut, rudder, stuffing boxes, should be checked for corrosion damage.. Don't totally freak out if the stuffing box is green..
<br /><br />That's about all I got..
