Need an ECU for 1996 200 efi
JPranger
Anyone have 'connections' that would enable me to get a used or new mercury # 824003A26 as inexpensive as possible ?? :redface:
Needed ASAP, boat is DOA...:mad:
blazer01
Re: Need an ECU for 1996 200 efi
call cary at cary's marine....281-312-9856.....ken sandbothe sent you
Faztbullet
Call Tony or Linda @ Brucatosvs.com and they can supply a replacment or may be able to repair our exixting one...
JPranger
Thanks for the quick responses. I'm checking with them now. :D
JPranger
Does anyone know if other merc part #?s will work? I know with numbers being superseded, sometimes this happens. I'm finding some of the other numbers for sale used like 8240043A1, 8240043A28, 8240043A30. :cool:
Fun Times
# 824003A26
The other numbers used in the past where,
824003T26, Newest #
824003A26, to
824003A8, the
8240038, Oldest #.;):D
Here is a place that may be able to repair your old one for you, or fine you another one, It's worth a call anyway.;)
http://simonmotorsports.com/
Good luck with it.:)
Faztbullet
Yep superseded several times but the Brucato unit does not use the TPI sensor,customer tunable and is $700 cheaper than a Merc unit,Tonys is $1025 vs Merc $1722
