Need anchoring help!
jash1178
I am brand new to boating and do so in mainly inland salt water. I have a 15' boat and the family and I were out yesterday and tried to anchor to fish. Well it didn't go so smoothly we drifted with the current, not sure if the anchor line was long enough or if I threw it right. Any anchoring tips would be great, I have one of those digger style anchors.
capt sam
Master Chief Petty Officer
Re: Need anchoring help!
there's alot of factors, is the anchor rated for the boat, do you have chain, how much anchor line was out, strong current/wind requires more line.
Bob_VT
If you mean you have a fluke style the rule is 7:1 for the amount of anchor line you have out. A length of chain will help an anchor grab the bottom and a standard roll of 100' of line is good for about 14-15' deep water in almost ANY weather.
Ned L
In order to comment at all on you situation, need to know approx how deep was the water, how much line you had out, & do you have any chain between the anchor & the rode (anchor line)? If you have a descent anchor with some reasonable chain, and the water isn't to deep, you should be able to get away with about 3:1 scope for a quick stop for some fishing (10' water : 30' line). As has been said, if you were staying for any length of time, &/or staying overnight, you should have at least a 7:1 scope (10' water : 70 feet line).
You shouldn't be 'thowing' the anchor, it should be lowered over the side, when it hits the bottom allow the rode to pay out as the boat drifts back, giving it a few light tugs as it pays out to help the achor 'set' (dig into) the bottom. Ideally, when you have the desired amount of rode out & it is cleated off, put the engine in reverse for a moment while having a hand on the rode to feel if the achor is set in the bottom holding or just bouncing along & not holding. You can also sight a couple of objects on shore to see if the boat is moving or or staying still while the engine is in reverse.
Chris1956
jash, if the bottom is mud, sand or some other relatively soft material, a 7# fluke anchor and 3/8", 3-strand twisted anchor line will work great. You will need 3-5 times the depth of the water in line length (scope) to anchor effectively. On that boat, with a 7# anchor, in most conditions on a bay, you do not require chain.
My 16 footer holds real well with a 2.5# fluke anchor and no chain. I only anchor in good conditions.
