No show
- Jul 16, 2007
- 63
I'm having trouble with tilt and trim if that's what you call it .
1)I belive I have manual tilt (not sure)
2)I is very difficult to lift motor I don't see how you can possibly lift from inside the boat.
3)I guess you lift the 2 tabs they move in conjuction with each other because they are connected. So I guess you can lift one but first you must lift motor a bit to move it . Then lift motor let go of tab and it will stay up .
4) When lowering motor lift a little bit lift tab and motor will drop but how does it lock, I see you need to put pin in adjustment hole and I guess the two hook clamps should lock on it so the motor doesn't fly up when in motion. But how does it lock, from outside the boat when I lower the motor it doesn't seem to lock when I push it I don't want to crack back of boat .
I see a rod going from the two hooks near the spring going down to the lower end towards the propeller I'm thinking It locks automaticly when you put it in gear. Need some good advice not too clear in repair manual if you can help I would appreciate it thanks...
