Boat: 1980 McKee Craft 17' Southporter
Motor: 1977 Evinrude 85 hp
I recently acquired this boat and the motor had a Chrysler SS prop on it. It is not a thru-hub exhaust prop and it seems a miracle the motor wasn't burned up. The previous owner must have never run it with this prop. I removed the prop and started the motor 1st try. Good/even compression across all cylinders. I've ordered a water pump kit and Vernatherm for standard maintenance. Will be going through the carbs as well.
I haven't splashed the boat yet so I have no baseline (RPMs, holeshot, top speed, etc.) Can anyone recommend a prop for this setup for starters? I prefer to err on the side of caution and I'm not interested in achieving maximum speed. I will be buying a spare so I can make adjustments with that prop.
