Hi all--- I'm a newbie on this sight and somewhat new to engine tinkering, so please be patient with me. I just went to Florida from NC and got my late grandfathers johnson 35h/p 1985 engine. I am replacing the original johnson 35h/p 1962 that was on a freebie/give-a-way 1966 Duo boat-unfortunately, even after numerous very helpful advice and research on this sight, i couldnt get the older motor to even fire grrrrrr!!!- Anyhow, I have a few simple questions:<br />My intention is to purchase a deep cycle starting battery to start the motor and run the running lights.<br />I currently have an Everstart deep cycle trolling battery 75 hrs, reserve 100 hrs the cranking capacity has worn off, @ 1 year old though-- apparently ill buy a better charger, too. need a trickle or low amp charger-----duh<<<<<<<<br /><br />I was wondering if this battery will -trolling- power my trolling motor, a bilge pump, and fish detector? possibly put the bilge on the starter battery, since it will be infrequently used<br /><br />I'm in maintenance and at work I have seen a few switches that can tolerate 10amps,250vac/15amp,125vac are these proper? or should i get the marine switches i have seen in the forum? Additionally, how do i connect at the terminals? Can u overlap on the screw terminals, convert to all alligator clamps and overlap? oooo, i just thought of someting, it should be tied into one line to the battery possibly hmmmm. Well, trying to endeavor through this, any advice would be extermeley appreciated!!<br />ty fellas---aiko09<br />ps any Duo info would be g8!!
