Re: Need GPS Speedometer advice
I don't recall ever disagreeing with you (in about 12 years), Jim, but please allow me to nit pick a little. We might disagree a just a bit.
The basic, repeated calculation done in a GPS receiver is location, in 3 dimensional space, based on measured distance from 3 or more satellites (as many as 12).
Far simpler calculations determine distance between measured locations over time. The calculated speed is based on the distance between measured locations, including X,Y and Z axis movement. So changes in altitude would be included (I agree that wouldn't be very likely when afloat.
). I am not sure whether your "deduction" and my "calculation" are the same thing.
There is a common misunderstanding:
The "built in" error in location (for civilian use) of up to 3 meters (with WAAS) translates to error in speed calculations. Not so, because the error is constant from one measurement to the next (or the displayed track would be a sawtooth), so the distance calculation is accurate to a few micrometers and speed calculation to millimeters per hour.
No, I didn't lift this from some techno-blog. I deduced it from what tech data I know and some grade school fizix (
