just bought a '75 6hp, traded my '73 4hp and 150bucks for it, tested it in tank at the sellers house before buying, everything worked great , it sounded great and i was very excited to get it home. took it out to my local creek the next day started it up warmed it up everything seemed fine, i had my friend and i plus 4 rods, a cooler, battery, troll motr, anchor, tackle bags, pfds , dry box, 3gal fuel tank ect, loaded into a 12ft hd johnboat, i was all ready to go until i put it in gear, at full throt it went @ as fast as my 4 hp! i took it home and began doing some tests, spark test, compression tst ect. found no spark in lower cyl (#2), i know i need to take the flywheel off to inspect the ignition sys, but , i can not figure out how to lock the flywheel so i can loosen the nut, any ideas????? also is the fly wheel nut standard or reverse thread
