Ok. Got on the water today and overheated at high speed. Before I turned it on, keyed it up and overheat alarm went off. Unplugged temp sensor and because thought sensor was bad. Got on water at boat overheated at WOT. Prop is is rough condition(not horrible).
I have replaced:
Thermostat OEM
Impeller Assembly
Changed lower unit fluid
Compression: #1 95 #2 95 #120
I am stumped. Please help with any guidance.
I have replaced:
Thermostat OEM
Impeller Assembly
