Saskatoon2005
Master Chief Petty Officer
- Apr 27, 2005
- 810
Hello all and thank-you in advance for your help...<br /><br /> I am having trouble with my 1978 Mercury Outboard. It is a 7.5 H.P. I took off the carbueretor and took it apart and cleaned it right out. I changed the gas, put brand new gas in it and finally after what seemed like forever...it started. The motor had to run with the choke pulled out half way.<br /><br /> Here is the problem. I turned off the motor for about two hours, and when I tried to start it again I could not get it going. I am using the original 1978 gas tank, you know, the one that is completely made of steel. I could only get the motor started in a pail of water and I had to have it in gear. The motor only ran for a couple of seconds and then quit. I could not get it started in the neutral position. I was wondering if the old gas tank could have impurities getting into the fuel and then corrupting the gas flow. Please help me as I thought it was running perfect and had planned to use it tomorrow but now I can not get it to run at all. Once again Tank-you in advance for your help.
